DATUM TARGETS
  • Thread starter Thread starter vandewinckel
  • Start date Start date
V
vandewinckel
Guest
Good Morning,
I'm using wf4 m130. I'm trying to use a draft datum target with a diameter. I created the datum target and the diameter. The problem I'm having is the text for the diameter is larger than the target datum symbol. Is their a way to edit the textsize.
all you need to do is modify symbol circle size to fit 4 digits.
I am confused: what information you want to convey in drawing using this??
