Jun 2, 2003 #1 D denncoa Guest Hello, Is it possible to show datum points in a full are cross sectional view? Thanks
Jun 2, 2003 Thread starter #2 D dougr Guest Yes as long as the cs isn't total. You'll probably not be satisfied though so suggest putting a draft point on the datum-point and blank them.
Jun 2, 2003 Thread starter #3 D denncoa Guest could you elaborate on the process a little bit more? How do you get them to show up in a cross section? Thanks
Jun 2, 2003 Thread starter #5 D denncoa Guest For some reason the will not show up on the cross sections. They will however, show up in the regular views. thanks anyway.
Jun 2, 2003 Thread starter #6 D dougr Guest If your points are in front of your section plane then they will not show up... Likewise if you z-clip points, points won't show up behind your z-clip plane.
Jun 2, 2003 Thread starter #7 D denncoa Guest The datum points were set up directly on the cross section datum planes. I don't believe that I created z-clip points or planes.
Jun 2, 2003 Thread starter #9 D denncoa Guest I bet that is what my problem is. They are area crosssections. Thank you!
Jun 2, 2003 Thread starter #10 D dougr Guest Datum-curves don't show up on area cs either. To overcome this I use total cs and z-clip to the cs plane. Total cs are by far the most reliable and dependable..
