I have a part drawing that contains 6 sheets.
A pattern of 2 holes is called out as Datum B on Sheet 1.
I need to identify Datum B on the other sheets, but it's not necessary to callout the size of the holes. What is the proper way to do this (if there is a proper way)?
Do I need to callout the hole sizes every time?
Would it be ok to have a leader with "2x" and Datum B identifier attached to the leader?
