WOW MadOrange, didn't try to narrow down this topic at all, did you? You got my head spinning.
First of all, SE is heavily dependant upon File Properties. More so than any other Windows based or M$ program that I know. The beautiful part is that for most of the file properties that are, let's say
required, can be prefilled by the use of templates and standard data files. These standard data files, as I'm calling them, are text files (very easy to program) that can be stored on a network and pointed to by each specific user. They can also reside locally on some machines and pointed to there, depending on your need(s).
File control:
One of the tab in the file Properties dialogue box is Status: Available, In-Work, Review, Released, and Baselined. Basically, a brand new file is available to everyone. Once a designer begins working on it, he changes the status to in-work. This allows changes to the file by only the user that changed the status to in-work. It is available as read-only to everyone else. Once the file is complete and ready for production, the status is changes to release. This locks the file and can no longer be modified by anyone. In order to make changes to the file, you must rename the file (add a revision notation to the file name, for example). It then becomes available again for the cycle to repeat. Baseline is for purchased parts. They are modeled once and should never have to be changed again. Personally, my department does not use the status tab because we still consider the print document the master and therefore don't keep an electronic revision history. By doing so, we don't want to have to change the file name to keep a revision history.
Revisions / Link Management:
You are undoubtedly familiar with SolidWorks Explorer. SE has a program call Revision Manager which is just a SWX Explorer to the 10th degree. It is leagues ahead of SWX Explorer. Moving, renaming, copying, replacing files is a snap.
BOM:
SWX uses Excel to create the BOMS. SE has its own BOM creation tool that uses the data inside of the file properties to fill the fields. The upside, when you update the BOM, your added desicriptions are not removed as they are in SWX. The downside, you have to have all the fields you want in the BOM to be somewhere in the file properties. Typically they are located under the Custom tab. I remind you, though, that you can pre-fill tags in the Custom tab through templates and the standard data file. To save the data in the BOM to and outside program, such as Excel, is a simple right-click on the BOM. SE also creates reports, which are separate text files that can be of BOMS, Where-used, and several others.
New to v11:
Version 11 of SE adds a new program that is part of the core of SE called Insight. Insight is a PDM system based off of Microsoft SharePoint. It is completely transparent to the user. Insight is supposed to store all the files in a vault on the network drive. When a file is checked-out, Insight automatically caches a copy of the file on the local computer so all work is performed locally and not over the network. Insight will not utilize the network again until the file is checked back in. Insight is advertised as being bullet proof as far as tracking files and maintaining links. Since the investment for M$ SharePoint is rather involved, my company has not yet institued Insight so I cannot talk about it more than what I read on the SE newsgroups and get from other users.
--Scott
