Set up an array formula.
Suppose "Site Number" is in range A5:A4005, "Location" is in range B5:B4005, "Year" is in range C5:C4005, "Month" is in range D5
4005, "Depth" is in range E5:E4005, "Moisture" is in range F5:F4005, etc.
Suppose your criterias "Month" is in range D4, "Location" is in B4, "Depth" is in range E4 (you're after a range, so you'll actually have a MinDepth (say in cell E3) and MaxDepth (say in cell E4) for criterias).
You can count how many entries meet the criterias "Location", "Month", and "Depth" with the array formula:
=SUM(IF(B5:B4005=B4,IF(D5
4005=D4,IF(E5:E4005=E4,1,0))))
You can sum the moistures meeting the three criteria with the array formula:
4005=D4,IF(E5:E4005=E4,F5:F4005))))
TO ENTER AN ARRAY FORMULA you type the formula into the edit field and then enter it with the combination keystrokes CTRL+SHIFT+ENTER.
Of course the average is just the Sum divided by the Count. I don't know if you can combine these into a single formula. Maybe worth a try...
I noticed you want this to work with a range of depth. I didn't work that part completely out, but you should be able to do this by testing the Depth data against the Depth Criteria. Maybe something like replace "IF(E5:E4005=E4" with "IF(E5:E4005>E3,IF(E5:E4005<E4" will work. You'll have to play with this part a bit.
Good Luck,
ProjEngKLS
