Damper mechanism for floating objects
Parsnip
46
How can I design a damper to prevent vertical movement of an object suspended at a depth greater than 15m below a surface float which is driven by the wind and the tide. There is an elastomer link between the damper and the object and I am just having difficulty in the best way to approach any design work.
Cheers in advance
[bugeyed]
Clue: vertical movement relative to the surface float, or to average depth, or what?
Cheers
Greg Locock
Sorry - meant to state that the object must stay at the same depth regardless of what displacements the surface float is going through.
Cheers
Then mount it on a spring relative to the surface float, and add damping to its own vertical motion.
Cheers
Greg Locock
Oh, I'd have thought ribbons or a parachute like device would be adequate
Cheers
Greg Locock
