Hi all,
I am trying to quantify the effect on a kettle type heat exchanger in the event that it loses shell side flow and if I need a device to ensure a minimum flow to the shell side. So the details are as follows:
Tube Side:
This side cools hydrogen gas from around 100F to 40F at about 200,000 lbs/hr and due to the cooling, water condenses out. This stream then goes to a knock out drum and then towards a compressor. Pressure is 500 psig. Design = 300F/585 psig
Shell side:
Uses refrigerant which facilitates cooling via latent heat (phase change) at 34F with about 20000 lbs/hr of refrigerant (6% vapor and rest is liquid). Pressure is 50 psig. Vapor at the outlet then goes to KO drum as well and then to a compressor. Design = 300F/225 psig.
Both tubes and shell are Carbon Steel (SA-179 and SA-516-70 respectively).
So now if I assume that there is a sudden loss of flow to the shell side, all the refrigerant boils out and I am just left with hot tube side gas going in and coming out. So this should just reduce my compressor's efficiency. I am not sure if components within the compressor can get damaged here, similarly to how hotter pump product can cause internal damages.
Just based on design pressures and temperatures, the heat exchanger should be okay but how would I quantify the overpressure if any occurs? I don't believe any should occur but I could be wrong as the shell side is solely protected by and RV on the KO drum which is sized for tube rupture on a different exchanger I believe.
The only issue I can foresee, is if flow is lost and you have the tubes hot, and you reintroduce colder product, thermal shock may occur. Not sure how to determine if it actually does occur given or say it won't cause a failure without FEA or similar.
Any ideas/suggestions/tips on how I can quantify these effects ? I guess the exercise is similar to a HAZOP study but I just don't know if my thoughts are sufficient to say that another lay of protection is needed.
Tube Side:
Shell side:
