waqasmalik
Hi all,
I am confused about how to verify cylindricity? i have the concept that cylindricity does not require any datum reference and in order to check it you need to isolate the feature from rest of part. But in the figure( Attached) which i found in the book cylindricity has been checked in the same way as total run out. If this method of checking cylindricity is right then Wat will be the method of checking total run out?
Thanku
Thanku
