mrsander7
- Jun 28, 2011
- 5
I'm trying to determine what is wrong with a double-acting hydraulic cylinder with an external cap (static female radial gland). We're getting occasional leakage through the threads without visible damage to the o-ring. We're using an #344 Parker o-ring with a single backup and all dimensions and tolerances are exactly to spec as found in the Parker O-ring Design Handbook. We recently changed to a size larger o-ring/backup due to this problem, and leaking is still an issue.
In a particular case, the alignment of the cap and cylinder chamfer results in a satisfactory clearance (dist between cylinder od and cap id) behind the gland (on the thread side), but a 3-thousandths additional clearance BEFORE the gland (pressurized side).
Would such a clearance on the pressurized size of the gland be cause for leakage? If so, I'm trying to wrap my head around the mechanism behind the seal failure (why leaking may occur in this case, how the o-ring becomes unseated). Has anyone run into this issue before or have any insight?
Thanks!
Thanks!
