Cw 1
dgkhan
CA
Torsional warping constant.For certain hat channel section, I can draw in section wizard and can obtain all values except Cw. How to manually calculate it.
A close example in a Mathcad 2000 worksheet, one U-lipped section (like a lift core without door headers). For open sections; change the geometrical coordinates in the input and you have one hat section. Below will include a pdf printout.
 http://files.engineering.com/getfile.aspx?folder=99d384ed-cbae-4361-aa4d-fa6744278d29&file=U_Lipped.zip
In the first site below, under
Beams -> Cross sections -> User defined -> Torsion: from dxf
there is a sheet for calculating torsional properties of any section defined by a drawing.
Roark has a formula for a hat section, not sure whether it is exactly what you are looking for.
prex
: Online engineering calculations
: Magnetic brakes and launchers for fun rides
: Air bearing pads
The method of calculating Cw is given in "Cold-Formed Steel Structures" by Wei-Wen Yu. Expressions for hat sections and other cross sections are tabulated in Appendix B.
BA
I am not familiar with mathcad. Does any body has in Excel or any formula for hat channels.
A quick search of the internet provided an article on calculating the warping constant. . I have not read the article, but it looks interesting. For hat channels, the article has the same formula as AISI's Cold-Formed Steel Design Manual 2008 edition.
section wizard does give Cw Value also.It lists it as Iw = Sectorial moment of inertia
dgkhan, i am using ShapeDesigner Saas ( to compute torsion, warping properties and related stresses, is really simple and efficient and for the price is really interessting it costs me only 99$. hope this helps. and good luck.
