Cv correlation between gas and fluid? 3
jpyeck
If I have a valve with a known Cv for fluids (water specifically), is there a correlation that can be made to the Cv for gases (specifically CO2)?
Most manufacturers use the same Cv for liquids or vapors for a specific valve though you use different formulas. The ISA equations for control valves use Cv for gas and liquid.
Cv is the same. Cv is the amount of water (iGPM) that flow through the valve at a dP of one PSI.
You can transform this into a dimensionless K value if you like - this can be used for all gasses and liquids alike.
Best regards
Morten
TD2K,
Is that to say that I just need to convert the units of my water-based Cv to the flow units I want for CO2? Basically GPM to CFM?
No, you don't convert your cfm of CO2 into gpm and plug them into the formula for liquids (I think that is what you are asking].
Check your valve vendor catalogs, they will have the sizing equations in there. You can, depending on your pressure and temperature, use an ideal gas sizing equation or a real gas sizing equation (the latter if compressibility effects are significant].
A valve with a Cv of 1 will pass 1 gpm of water with a differential pressure of 1 psi. If you replace the water with CO2, you will pass a lot more than 1 'gpm' of CO2 gas, the amount depending on the pressure and temperature of the CO2.
It's an interesting question, I've never dug back through the sizing formulas for gas {for liquids, it's just Q = Cv * [dP/SG}^.5} to see how they 'relate' to liquids, if they do. But I think for you to find the answer to that question that would be a lot more work than what you are looking for.
As i stated previously. You can convert the Cv into a dimsionless loss coefficient (K) that can be used to calculate pressure drop for any fluid (single phase) be it a liquid or gas (allthough the formulas may differ and the valve may choke in which case the formula changes again).
Best regrads
Morten
You can use the same Cv for gases and liquids, but if teh pressure drop thru the valve exceeds 5% of the inelt pressure, tehn you should add a compressibility correction factor. See the ISA handbook of control valves
For liquids and low pressure drop gases;
W(lb/hr) = 63.2 * Cv *SQRT {DP(psi)/ sv,i(lbm/ft3)}
For gases where the DP/Pi > 0.05, then use the following :
W=63.2*Cv*Y*SQRT {x*Pi/sv,i}
Y=1-0.33(x/Fk/Xt)
x=min {DP/Pi, Fk/Xt)
Fk=(Cp/1.4/CV) ( this CV is heat capacity)
Xt= valve index for choked flow due to oblique shock waves, typically .75-.85 for globe, .65 angle, 0.2 ball
max value of Y is 0.67 , occurs during choked flow when
x= Fk/Xt
Cv is a non dimensional coefficient representing the equivalent orifice diameter of the opened valve.
Cv = 15 * D^2 when D is the equivalent orifice diameter in Inches.
You can find this info at
The lee company is a unique developer and manufacturee\r of micro hydraulic and pneumatic systems for aerospace and commercial uses.
MortenA
Thank you for the correction. However, what I wanted to emphesis is that Cv is a measure of the equivalent orifice diameter and therefore can be used with any fluid. Meaning is a property of the valve/orifice geometry only. My confussion was because I am used to Cd - discharge coefficient which is more natural to use (at least for me) because it is dimensionless and always less or equall to 1.
israelkk
Its easy to get confused re this matter. In europe we tend also to favor the dimensionless coefficient (often in Denmark/Germany refered to as K) since this can be used in any pressure/flow relation and not just for a valve.
Best regards
Morten
Cv is usually stated as 'gpm at 1 psid', but I think the correct units are
gpm/sqrt(psid)
Mike Halloran
NOT speaking for
DeAngelo Marine Exhaust Inc.
Ft. Lauderdale, FL, USA
