CV control valve
justitia
Petroleum
Jun 10, 2009
9
How can I figure out the flow coefficient CV under certain conditions?
The fluid is a gas.
Data available are: mass flowrate, inlet pressure, pressure drop, inlet temperature, vapour molecular weight,
compressibility factor, viscosity at inlet temperature and specific heat ratio.
I need to figure out it for a control valve with non-critical flow (dp<0.5p1).
Is it the same for any other type of valve?
Thanks.
