PhoenixDynamometer
Industrial
I avoid surface models whenever possible however, I have a connector from Turck that I downloaded and must work with. The model has 5 surface bodies and I am not able to extrude-cut any features. I am trying to cut away the lock nut but it either does not go away or it errors out with does not intersect the model. Is there a way to successfully extrude cut with surfaces or do I need to try and convert somehow to a single filled body?
Thanks in advance,
PD
Home of the world's most accurate and repeatable dynamometers, dynamometer accessories, and data acquisition & control software.
Thanks in advance,
PD
