Cutting off Dimensions 1
Terminus0
74
I'm trying to dimension to something fairly far away from the part itself and I don't want the dimension line to go off the drawing page.
Is there a way to cut off a dimension? To only have one leader the dimension and then the line ends at some point?
I used the hide dimension line command, because what I needed to do was linear foreshortened dimension which solidworks doesn't support.
It's not exactly what I wanted, but it's close enough.
You can right-click on any extension line and click "hide extension line". Then you can right-click on the half of the dimension line you don't want to see and click "hide dimension line".
-handleman, CSWP (The new, easy test)
You could also include a station plane and then reference all the dimensions to the plane.
-Kirby
Kirby Wilkerson
Remember, first define the problem, then solve it.
