Cutter Compensation G code palcement.
TACKS652
Automotive
Jan 18, 2006
21
When using G41 and or G42 is it required that the D0 command be on the same line as the G41-G42 command? My cuurent POST pusts the D0 on its own line which is one before the G41-G42 command is used.
I am getting conflicting information from the Shop floor on the process and would like some further input.
Check the programming manual that came with the machine tool for examples of how to turn on cutter compensation.
Ben Loosli
Sr IS Technologist
L-3 Communications
looslib, tried that but the manuals are MIA. Things are not real organized so I am using Trial by error.
Anyways I have edit the Post to add the "D0" command in the same line as the G41-G42 and the it appears that it will suffice. I am using RESISTERS instead of the DO being an input value at the line command.
Late reply but:
The truth is G41/42 are modal commmands. On almost any machine you can put it right there with the length offset such as:
G43 Z1.1234 H12 D12
It works both places. One advantage to putting it right with the H after the tool change is if you need use a different toolnumber - it's an easy edit in one place. It looks cleaner to me as well.
Some folks like it on every G4x line - just in case they do a mid program start and want to make sure the control is using the proper offset without manually resetting it - especially if the operator is "green".
Bill
