S
scottm
Guest
So look a stapler base - it is a die cast part with a draft, the bottom (once you take the rubber off) is hollow with some ribs, etc. in it.
If I was using my old software I would make a second solid with a draft and subtract it from the main solid. Shell doesn't work because its not really a shell.
Is there any boolean subtract available in Pro-E?
