How to control display of assembly cuts by using.
Edit Definition
or
Intersect
When you create an assembly cut there is an option for what you want the feature to intersect and where you want the cut to be displayed Top Level, Part Level, Sel Level. You will find an Intersect option on the dashboard which has a simple dialog attached to it.
The default option is TopLevel and proe will AutoIntersect all parts that the feature goes through. Pro/E used to prompt the user for intersection before completing an assembly cut before Wildfire.
Now to access this functionality you must select the
Intersect Tab on the Dashboard to tell proe where you wan't the cut to be shown.
To get what you want you can Redefine the feature and select Intersect
So to fix your cut display you can select the feature and choose
Edit Definition or Intersect.
In both cases converting the Intersection from top level to Part Level is basically the same.
1. Uncheck the Auto Update option2. Select the parts you want to show the cuts at part level3. Right Click choose from options displayed Top Level, Part Level
If you use Intersect it will be quicker and use a slightly different dialog window then the one on the Dashboard and has different names for some of the buttons. You may also be able to see a bug that I found.
Bug
When you select a Part that has Part Level as the option it displays Top Level as Top Leve.
Intersect Bug
I'd be interested in knowing if you also see the bug I described.
Michael
Edited by: mjcole_ptc
