Customizing Toolbar, different Buttons but same dll
nxplm
Computer
DE
HI All,
I want to create a customize Toolbar (.tbr) I would like to know if it is possible to create 2 buttons that they call the same DLL but each one calls different functions (callbacks).
I just can do it creating the actions in separately DLLs. But for the purpose of my project is not useful.
I will appreciate it!!
Thank your very much
I haven't tried it with a TBR file, but it works with a MEN file.
NX 6.0.5.3 (NX 8 Testing)
Windows 7 64
phillpd,
have You tried without creating a "Application_Button" and executing callbacks?
Here's the section I use ...
MENU KMT_GKAD!4X
BUTTON KMT_GKAD_NAV
LABEL Navigator...
ACTIONS MkNavigator.dll
BUTTON KMT_GKAD_PREFS
LABEL Preferences...
BUTTON KMT_GKAD_PREP_REL
LABEL Hide Tools...
END_OF_MENU
Windows 7 64
Thanks phillpd,
I knew that solution, but my question goes beyond this point.
How do you differentiate in your own application which button has been pressed?
Thank you again for your comments,
Daniel
The text of the button name is the first argument to UFUSER
Windows 7 64
Is it possible to add some parameters to the application? I can not find the solution.
For example:
VERSION 120
EDIT UG_GATEWAY_MAIN_MENUBAR
MENU UG_APPLICATION
BUTTON wag_ENG_CONVERT
ACTIONS "start "\"C:\Program Files\Siemens\NX 8.0\UGII\managed\Toolbar.exe" ipAdress""
END_OF_MENU
Like I posted it does not work...
Thank you again for your help.
It's an argument inside the code
Windows 7 64
I have seen that it is easier and possible using NX Open C++ with UFUSR;
But I am developing applications in C#,
Is there a way to wrap C++ entry function in C#??
Thank you very much again!
