customize colour of hidden lines
  • Thread starter Thread starter paoloz
  • Start date Start date
P
paoloz
Guest
Hi all,
Is it possible to change the colours of the lines in my drawing?
For example, I want to customize the hidden lines in green for all my new drawings.
Which variable should I set?
Bye,
Paolo
Yes there is such a config.pro setting !!
Set in your config.pro the variable system_hidden_color followed with three decimals representing the intensity of the RGB value. (Red Green Blue). Remark: Those decimal values are percentages not the exact RGB-value (= between 0 and 255), if you want 60% of the green color and 60% of the blue color you have to set:
system_hidden_color 0 60 60
... in your config.pro and the result will be that the hidden lines arein an bleu/grey color.
so if you like a green color for your hidden lines, put
system_hidden_color 0 100 0
in your config.pro.
FDDesign
Edited by: FDdesign
