customised line types
mechanicaldup
NA
how do you create customised line types?
and where can i download line types?
Easiest way is to go find the AutoCAD acad.lin file, make a copy of it, open your copy with a text editor like Notepad, and see how the basic lines are put together. AutoCAD help will give you a few clues, but I learned quicker by just experimenting with a copy of the standard .lin file.
If you have the express tools loaded check out the tool MAKE LINETYPE.
what is the fuction of the following parameters in the lintype.lin code
STANDARD,
S
R
X
Y
-.2
code below:
*HOT_WATER_SUPPLY,Hot water supply ---- HW ---- HW ---- HW ----
A,.5,-.2,["HW",STANDARD,S=.1,R=0.0,X=-0.1,Y=-.05],-.2
A= ALIGNMENT (ALWAYS A)
.5= PEN DOWN .5 UNITS
-2= PICK PEN UP .2 UNITS
"HW"= TEXT
STANDARD= TEXT STYLE
S= SCALE OF TEXT
R= ROTATION OF TEXT
X= HORIZONTAL OFFSET OF TEXT
Y= VERTICAL OFFSET OF TEXT
All spelled out in the Customization Guide of the Online Manuals
1. Open acad.lin file.
2. Copy the existing file example and past it at the end of the page.
3. Modify it to what you want.
Tip: The better to keep the standard default setting.
