Customer holes in SW toolbox database .... help
Jamaz17
Automotive
CA
I have added a few customer counter bored holes to the hole wizard database. At first they worked fine but after a few weeks we decided to change how they were named (just the new holes) Now, when I select those holes in the hole wizard I get the msg
'The dimension value 0 is out of range. The old Value or _______ will be restored'
The ______ seems to be whatever the clearance of the last counter bored hole that was selected in the hold wizard. If I say 'ok' on that msg SW will but the customer holes in but using the _____ value? Any ideas?
I assume you don't have a backup of the working customised file?
Have you tried re-naming back to the original name?
Have you tried re-creating the custom holes and deleting the re-named ones?
[cheers]
It seems the dimension value 0 is the thru clearance hole for the counter bore. There is a value for the clearance hole in the standard but SW doesn't seem to see it so it decides to use '0'. I've tried re-naming the holes as well as deleting them altogether and starting again, nothing seems to work... any more ideas?
