Let me tell you very clearly
I am going to talk about only assigning material
What i am going to talk about is in WF2
First assign materials for all the parts in the assembly
Now come back to the assembly
go to analysis-model check-configure model check
drop down conditional settings- manually choose conf-make it heavy
Now drop down configuration settings- drop down start files- select default
start
select add row- select on the new blank row created
select part below the field value- below select add check parameter-
below type some short cut key like (MAT)- below type MATERIAL_INFO
select add item- save - close
Now go to analysis-model check-model check interactive
Now parameters would have generated in the part files with the material name assigned
Bring this parameter to drawing by adding a parameter asm.mbr.userdefined(short
cut key like (MAT)
all other works in the same fashion
explore analysis-model check-configure model check
Now drop down configuration settings- drop down check files-explore for
names of the parameters
I think this process is little big
If you are not able to do this mail me to
dony@tataelxsi.co.in
Will try to help you
