Custom 3D View Update
aszepesi
81
Dear All,
I created a custom view in Modeling environment. I created a drawing view from this custom view in the Drafting environment. I switched to Modeling and changed the custom view's orientation and I used the MB3 to save it. When I switch back into the drafting environment I find that the existing drafting view from the custom view isn't updated.
Is it possible to update the modified custom 3D view in the drawing sheet?
Thanks a lot
NX7.5.4, NX7.5.5, NX8.0.0, NX8.0.1
RMB on the custom view in the part navigator and choose update?
Best regards,
Michaël.
NX7.5.4.4 + TC Unified 8.3
Win 7 64 bit
Have you tried this update command?
I have tried all Update possibilities in the Part Navigator tree and the Tools, Update menu.
Attila Szepesi
support engineer
graphIT Ltd.
Drafting views provide a snapshot of the model when they are placed and are in general not associative to the model view. There is a relatively easy way to reorient your drafting view, but other drafting entities (dimensions, section lines, etc) may lose their associativity. To reorient your drafting view: [ol][li]enter modeling application, right click in a blank area and use the 'orient view' command to orient your view to your custom view[/li][li]orient your WCS to the current view (Format -> WCS -> Orient...) and save a datum csys on the WCS[/li][li]switch back to drafting, right click on your view and choose Edit[/li][li]using the orient view tool, you can pick the Z axis of the datum csys for the view normal and the X axis, the view orientation will update[/li][li]reattach dimensions and other entities as necessary[/li][/ol]
Hi cowski,
I'm interesting to your solution, but I can't replicate this workflow.
Can you provide with a simple video ?
This solution is still valid on NX 8 and with master model approach ?
Thank you...
Using NX 8 and TC8.3
