CurveByTable.Add Method Arguments
jwSEI
Aerospace
Does anyone have experience using CurveByTable in conjunction with VB? If so, could you please briefly explain the proper use of the "Add" method for this object?
I have experimented with various choices for the arguments "Closure", "ClosureType", "UnitType", and "dTolerance" without finding a successful combination. Every time I've run the "Add" method I've received an "Invalid Procedure Call or Argument" error.
A sample line of code would be great, too.
Thanks,
-Jon
I'm having this same problem. Any help would be appriciated.
Thanks,
Josh
Here is a sample I got from Kash J. Rangan at Solid Edge Support. I hope it helps.
Option Explicit
Dim objApp As SolidEdgeFramework.Application
Dim objDoc As SolidEdgePart.PartDocument
Dim objCurveByTable As SolidEdgePart.CurveByTable
Dim objRefPln As RefPlane
Private Sub Form_Load()
Set objApp = GetObject(, "SolidEdge.Application")
Set objDoc = objApp.ActiveDocument
'CurveType = only igDirectFit and igLeastSquareFit will work
'Closure = igNormal, igClosed
'ClosureType = igNatural, igPeriodic
'UnitType = Null, Character string
Set objCurveByTable =
objDoc.Constructions.CurvesByTables.Add(filepath:="c:\Vb
Examples\CurveByTable\CurveByTable.xls", _
CurveType:=igLeastSquareFit, _
dtolerance:=0.0001, _
ClosureType:=igPeriodic)
objCurveByTable.Visible = True
End
End Sub
Thanks for digging this up, Josh. I'm going to give it a try and see if I can get my code working now.
Thanks again,
Jon
Does anyone have experience using Threads in conjunction with VB? If so, could you please briefly explain the proper use of the "Add" method for this object?
Thanks,
Mlody
