cmelguet
- Jul 19, 2009
- 64
Can someone give a procedure to correctly size a current transformer to be use in protection ?. I guest it should be something like:
- pick ratio to be below of the nominal current of the system.
- pick accuracy limit factor to be above the maximum fault current.
- pick VA of transformer to match burden of the relay and cables
How you determine the knee point you should specify?
How you determine the correct secundary impedance you should specify?
Thanks.
Cristian
Thanks.
Cristian
