I am looking for a circuit for a constant current supply for luxeon 1W or higher Stars. My intended use is general lighting and task lighting. Everything I have found on chips and designs assumes supply voltage lower than the LED's operating voltage and uses a boost circuit of some sort. This adds cost and size. I do not want to waste power in equalizing resistors for each LED. Constant current will give better diode light matching.
I would like to be able to make a bunch of the circuits with each being capable of a series string of 1-6 LEDs. I can feed the current source circuit whatever voltage necessary. An off-line supply would be good. The LEDs need 350 ma. Low cost and small size are both key considerations.
Pulse width modulation for brightness and/or power reduction at full visible brightness would be a plus.
