Hi kenre;
I just looked at this thread. As I read it, I kept thinking, Ohm's law, I=V/R. Use a shunt resistor and control the voltage across the shunt. This will give accurate current control with minimum losses.
VE1BLL said basically what I was thinking.
If your power supply has a voltage regulator, you may need to change only one or two connections in the power supply.
If you use a 1 ohm resistor in series with the load, then the current will equal the voltage. Use a 0.1 ohm shunt (more practical) and the current will equal 10 X the voltage across the shunt.
If you can post the circuit diagram I am sure someone will be able to identify the wire that needs to be reconnected.
With a 0.1 ohm shunt resistor, the loss in the shunt at 30 amps output will be 90 watts. (I^2*R)
This will maintain the set current even when the load resistance changes.
Bill
"Why not the best?"
Jimmy Carter
