I have a 12V dc battery, which will be fully charged (and will be charged via an alternator), and a 12V dc battery which will be at any level of charge, and when the switch is thrown, they will be connected in parallel, so the fully charged one will charge the discharged one. They will be connected via (most likely) 8AWG wire, 30' or so. I need a device to go in series to limit the current to a max of 20A or so, to prevent the wire from melting and such.
Cheap is priority
I'm not sure what the name of such a component would be, or if they're easily obtainable, or if I could build such a device with a slew of resistors/capacitors.
I am a mechanical engineer, please go easy
Cheap is priority
