Thanks for your replies. Not too late, work scheduled for tommorrow Dec 15. Project is in New York area. Todays temp is about 20 degrees F now, and maybe 30 deg at noon
Contractor naturally wants to pull blankets and forms after 3 days. While I would like 7 days, the cylinders will stay out there and have to pass. If they fail, I will have them take cores to verify. My thinking on this is that the main concern is initial concrete failure in the first few days.
After that, the concrete can take all the times it needs to reach strength. And better weather is forecast for next week.
(Even getting them to use blankets caused a rucus. One sub was fired for refusing to use blankets, and came back to pull 80% of his in-place rebar out. Police were needed to stop the mayhem - I missed it)
On another project, specs call for 4500 psi and results now after 30 days are 3000 psi. Concrete supplier has pulled his computer tickets for the loads, and sees nothing wrong.
Any thoughts. GC plans to core every week to see if strength improves with time. This work was poured a month ago or so when weather was fine. Flyash was used in the mix. What are the pluses and minus's of flyash
