Any way you model this will be an approximation. You may be able to use the average slope, based on the total length and the drop from the inlet to the outlet. You could also increase the Manning's value to allow for the extra friction at the bends. Do a sensitivity analysis on these factors to see how much is effects the final routing. You may even find that the culvert operates under inlet control, and that these factors don't effect the routing at all.
