JDmagnet
- Jan 19, 2009
- 5
I work in the field of superconducting magnet design. I am now designing a liquid helium vessel that carries 100 psi fluid pressure max. at -269 deg C. in addition to applied loads from magnetic coils creating as much as 800 psi mechanical loads on varying areas of the vessel. It is a flat plate welded structure trying to be designed to intent of Sec VIII, div 2., even though it is not to be a code vessel. It has many space constraints as these devices usually have. Current von Mises from FEA peaks around 70 ksi. An elastic-plastic analysis criteria will be applied to the vessel if possible. The magnetic loads are limiting in the fact that a disturbance creates a quench which dumps the stored energy of the magnet as heat within a couple seconds, the lorentz force load being gone accordingly. The heat goes into the helium which then vaporizes and uses the 100 psi overpressure protection. It is important to note here that the lorentz forces require a temp of -267 C or lower (superconductivity), otherwise only the 100 psi pressure applies to the vessel between room temp and that value, no added pressure from the coils. Stainless steels 304 and 316 have significantly increased strength at these temperatures, especially 304N and 316N but the Sec II tables, Part D, Table 5A list allowables below 100F only. Is there any provision for increased allowables at low temperature in the code for these materials?
