Crosshatch (solid option)............... 1
CAD2015
Automotive
I want to update the 2D drawing adding the colors that have been specified (red, blue and white).
I tried to use the "crosshatch" tool, but the version that I use (2212) doesn't provide a full color type (solid option).
Are there other option available in order to place the full (solid) color on the target area?
Thank you!
I suggest using the "area fill" command. It does the same thing as the crosshatch command, except there is an "solid fill" option. Make sure to turn off the drawing monochrome mode so that you can see the color you picked.
I have no idea why there are 2 nearly identical commands for this...
