Cross Flow Heat Transfer
StevenKingdon
Hello, I am new to the forum (and engineering)
I'm completing a work term for university, and my mentor suggested a report topic that involves cross flow heat transfer. The only problem is that I have not taken the course yet, so I am trying to learn it all myself with no luck.
My question is how much heat is lost in a 0.1016 m (4") Carbon Steel Pipe (wall thickness 0.006 m or 0.237") carrying water at 80°C (176°F). The outside temperature is -2.37°C (27.7°F) with a wind speed of 5 m/s (16.4ft/s).
I am trying to determine how much input would be required from a furnace to increase the heat if the pipe had insulation stripped, while relating length of pipe stripped to loss in heating therefore increased cost. These are the values I was using.
----------------------------Water @ 80°C------------Carbon Steel-----------Calcium Silicate------------------Air @ -2.31
Density---------------------9.7121E+2 kg/m^3----------------------------------------------------------------1.3043 kg/m^3
Dynamic Viscosity-----------3.4599E-4 kg/ms-----------------------------------------------------------------1.7116E-5 kg/ms
Kinematic Viscosity---------3.5625E-7 m^2/s-----------------------------------------------------------------1.3123E-5 m^2/s
Specific Heat---------------4.0696E+3 J/kgK-----------------------------------------------------------------1.0055E+3 J/kgK
Conductivity----------------0.67 W/mK------------------54 W/mK-----------------0.063 W/mK-------------------0.023895 W/mK
Prandtl Number--------------2.1015--------------------------------------------------------------------------0.72029
I have found the heat content of No.1 Furnace oil to be 134000 BTU/gallon.
I have used the formula q=2πkL(T1-T2)/ln⁡(r_2/r_1 ) , and recieved an answer of q = 237,106*L and this would give me my W/m. But I'm not sure if this is remotely correct as is doesn't take into consideration wind.
Sorry for being long winded, I'm just all out of options.
We normally dont assist with student postings, but your answer may well be within 10% of the estimate obtained with a great deal more work - this is because the insulation resistance to heat transfer may well be more than 90% of the total heat transfer resistance. Heat content for fuel oil sounds about right, and so does your formual for heat transfer across an insulation layer.
I worked it out and found an answer that my supervisor and I are satisfied with which includes losses due to cross flow.
