Not certain it would affect the crimp, if you locate the bend away from the crimp barrel (i.e. in the flat between crimp barrel and spade opening). To be safe, you could bend the part first (I would clamp into the termainal block you intend to install it in and free-bend to achieve whatever alignment you want), then remove, crimp wire, and re-install.
