Jul 17, 2012 #1 H herb Guest Two questions: 1) Can Creo1 read Creo2 files? 2) Can Creo1 read .stp files from Creo2?
Jul 17, 2012 Thread starter #2 D dr_gallup Guest No Yes Look up the ATB (associative topology bus), it does give a way to open files in older versions, there are many caveats.
Mar 5, 2013 Thread starter #3 M Mikael_Haell Guest What parametres do i change in the ATB to be able to make a stp-file from Creo2 to work in Creo?
Mar 5, 2013 Thread starter #4 D dr_gallup Guest If you are using STEP files you don't need the ATB, but you will have dumb geometry with no features or parametrics. ATB is a way to be able to open and edit files in older versions of Pro/E/Creo.
Mar 5, 2013 Thread starter #5 J j.s.srihari Guest STEP means STandardized Exchange of Product file. U can open in any modelling software without feature tree
