Creo Parametric 2.0 parameters
jeffatmines
I'm relatively new to Creo, and have a couple questions regarding parameters. I notice that Creo is pulling parameters from many different sources. Where is it pulling the values for parameters like PDMREV and PROI_REVISION/PROI_VERSION? The source only says "PDM" which doesn't really tell me much. The reason I ask is that I also have in my parameters PTC_WM_VERSION, PTC_WM_REVISION, and PTC_WM_ITERATION which show the source as Windchill. Thanks!
Jeff Parham
Colorado School of Mines '09
Mecahnical Design Engineer
Those are older parameters embedded in the core start parts that PTC uses. Not sure how to delete them in Creo. In WF, you could revert to the old UI for parameters and delete them.
Ben Loosli
