Creo component assembly
  • Thread starter Thread starter Zrider
  • Start date Start date
Z
Zrider
Guest
How do I get Creo to show from the component placement window, the 'Show Component in a Separate Window While Specifying Constraints' and the 'Show Component in the Assembly Window While Specifying Contstraints' by default?
I did not find a config option so that leaves creating a mapkey for the various instances you want to occur
(ie, initial assemble vs edit definition)
Config option:
comp_assemble_start CONSTRAIN_IN_WINDOW
I knew it was there somewhere, thanks.
