Creo 2.0 Simulate - Stuck in optimization
  • Thread starter Thread starter Gubo
  • Start date Start date
G
Gubo
Guest
Hi all,
I looked into old threads and I found something about the same issue, but no solution.
I set up a very simple mechanical analysis. It runs fine in a few seconds.
If I set up the same analysis for an optimization study, it gets stuck while trying to open Creo to change the optimized feature.
Summary:
Optimization Design Study
Using Gradient Projection Optimization Algorithm
Sat Feb 15, 2014 20:31:27
No Goal Specified
Limit: 1
Analysis: Displ1
Load Set: LoadSet1
Vertical_pos = 5.9000e-002
Parameter Min. Value Initial Value Max. Value
FORCE 10 11 20
Optimization Convergence Tolerance: 1 %
Maximum Number of Optimization Iterations: 20
Begin Analysis of Limits of Initial Design (20:31:27)
Log:
Creo Simulate Structure Version P-10-18:spg
Log for Design Study "study1"
Engine Command with the specified command line options:
C:\Program Files\PTC\Creo 2.0\Common Files\M010\mech\x86e_win64\bin\msengine.exe study1 -i . -w . -solram 8000 -sturm default -num_threads ALL
Begin Creating Database for Design Study
Elapsed Time (sec): 0.13
CPU Time (sec): 0.12
Memory Usage (kb): 30801
Work Dir Disk Usage (kb): 0
Step Elapsed Time (sec): 0.00
Step CPU Time (sec): 0.00
Begin Integrated Mode Error Checking
Checking the model before creating elements...
These checks take into account the fact that AutoGEM will
automatically create elements in volumes with material
properties, on surfaces with shell properties, and on curves
with beam section properties.
Step Elapsed Time (sec): 0.01
Step CPU Time (sec): 0.02
Begin Generating Elements
Elapsed Time (sec): 0.14
CPU Time (sec): 0.14
Copying elements from an existing study model ...
Successfully copied elements from an existing study model.
A complete set of elements already exists.
OK
Step Elapsed Time (sec): 0.20
Step CPU Time (sec): 0.19
Elapsed Time (sec): 0.34
CPU Time (sec): 0.33
Memory Usage (kb): 43370
Checking the model after creating elements...
Excluded elements may be required near one or more
loads due to concentrated stresses.No errors were found in the model.Updating the geometry...
Starting Creo in the background...
Command shell:
pro_command defined to "C:\Program Files\PTC\Creo 2.0\Parametric\bin\parametric.
exe" "C:\Program Files\PTC\Creo 2.0\Parametric\bin\parametric.psf"
Any idea?
Gubo
It's now more than 1.5y ago this thread opend;
Is there a fix?
I'm having the same trouble on 2 PC's.
It keep looking like this:
