seakins5100
Aerospace
- Jul 16, 2008
- 4
I am currently in the process of modeling an unshrouded axial wheel airfoil to be used for die creation. The customer requires a compound fillet between the hub of the wheel and the airfoil.
The larger of the radii must have its center located at a set distance from the 'platform' or inner flowpath of the part, and it is to be tangent to the airfoil. The smaller of the radii is then blended with the larger at the flowpath.
I've been able to recreate this profile in sketch mode, but I have been unable to use this profile to create the fillet I need.
Below is the profile I would like to use for my blend.
Any help would be greatly appreciated. Thank you.
