Creating volume for CFD analysis
  • Thread starter Thread starter executnr
  • Start date Start date
E
executnr
Guest
Is there a simple way to create a solid model of the air space in a sheet metal assembly?.... It would be nice if it were parametric to the original model as well
Our assembly is basically pieces of flat (and sometimes bent) sheet metal put together making essential odd shaped duct work.
Any thoughts?
WDS
WDS,
I use "Cutout" from assembly operations in the Edit menu. Take a look at the help on that topic - it should be enough to kick you off.
Chris
