Creating text protrusions on a cylindrical surface
  • Thread starter Thread starter Guest
  • Start date Start date
G
Guest
Guest
Once you have your datum curve on the surface, create an Area Offset feature:Insert > Advanced > Area Offset > Sket Region > SideNrmToSkt). Use a make datum for the sketching plane tangent to the cylinder at the location of the text. In sketcher, Use Edge > Loop, and select the existing datum curve text that you had before. Enter a postive offset for protrusions, negative offset for a cut.
This works best with minimum text. If you have a lot of text, sketcher can take a long time to regenerate because you have a lot of little skeched entities.
Create a surface, can be a copy. Use flatten quilt. Sketch an extruded protrusion on the flat quit and then create a solid bend which will automatically bend it back to it's original shape. This is robust and doesn't take long to regen.
if the inscription will be neccessary in programing room, and the programing guy is work with Pro/E, then make it simple:
Cosmetic -> Groove
adicar@home.ro
How is cosmetic groove different from projecting a datum curve?
If you project a datum curve you can at least cross over multiple surfaces. This may be quicker in some cases for programming but I usually need to show the text to the client in its finished state before they can approve it.
Cosmetic - > Groove it's one Pr/E definition function used to engraving only if you use Pro/NC, if not it's only one projected curve.
adicar@home.ro
