Creating "page 2" drawing sheets
  • Thread starter Thread starter CAD guy
  • Start date Start date
C
CAD guy
Guest
I'm fairly new to Solidworks, using Solidworks 2006. It seems Solidworks only has "sheet 1" drawing formats. I want to create drawing sheets for after sheet 1 that are simplier formats (without the entire block as sheet 1). How can I create a "sheet 2" drawing format? I'd like the "sheet 2" format to just have the part number, revision, and sheet number for instance.
Thanks!
Edited by: CAD guy
You can add sheets as follow:
- Right click mouse on anywhere on the sheet.
- Slelect "Add Sheet"
- You can now select a sheet fromat, then press "OK"
Another tip:
for learning Solidworks go to the help menu and select the "online Tutorial"
This is tutorial that's on your own computer, you 're not going online on the internet so you don't need a internet connection to learn solidworks.
In this tutorial you can choose from many subject to learn something about.
Good luck and enjoy
You may also want to create a template with multiple sheets in addition to a template with multiple sheets. I've found that you can't add a template as a second sheet, only a format. This means you lose notes and tables etc.
A key to understanding this is that a drawing template and a format are two separate items:
Drawing Template = Drawing Format + tables and notes
Peter
