creating multi sheet 'tiff'
KimBellingrath
I searched the archived threads and cannot find the answer to this question: How do I get multi-sheet drawings to print as 'tiff's? I have everything set pretty well but I can't seem to get the subsequent sheets to print - only sht1. What is the line in the 'pcf' file for that?
Thanks in advance for your help.
plot_sheets all default that's from the pcf file
Not sure on tiff...but save as tiff from drawing, if you change your sheet numbers the current one is printed
I'm sure someone will have a better answer
on jpegs... if I go with these it works fine...allows me to name ..myname.jpg then increments the sheets fine
plotter JPEG
button_name JPEG
button_help Print to any printer that supports JPEG format.
plot_drawing_format YES default
plot_segmented NO
plot_roll_media NO default
plot_handshake YES default
plot_label NO default
create_separate_files yes default
plot_with_panzoom YES default
rotate_plotting NO default
allow_file_naming YES
plot_name NO
interface_quality 3 default
plot_destination file default
pen_table_file table.pnt
paper_size A default
paper_outline NO default
plot_clip NO default
plot_area NO default
On tiff basically all the same setting except if I name the file other than default..bam pro closes..if I take the default name let it increment it.. reanme the plt files..works fine..???
plotter TIFF
button_name TIFF
button_help Print to any printer that supports TIFF format.
plot_segmented NO
create_separate_files YES default
plot_name NO
I have the same settings but it only creates one sheet (sheet 2 for some reason) Anyone else have any ideas?
