Creating a watermark in SW2008
CADShark
Has anyone tried making their own watermark in SW2008.
You know something that would go across the drawing that would say DRAFT or something. I print on a BW laser printer but everything seems to come out black. I haven't tried printing in grayscale yet.
"Perfection - a result of many mistakes."
Blair H.
SW 2007 sp2.0, HP x6400, 2.0ghz dual core xeon, 2.0 GB ram, Nvidia Quadro FX 1500
I've done that before. We used Grayscale or maybe the line weight.
We had the Watermark on a layer called...you guessed it...Watermark. And the text was actually in the Title Block template. The releasing routine would turn off that layer and add the appropriate text/stamps/blocks/etc... Most of the users didn't even know that it was just a layer that they themselves could turn off and on, so we didn't have to worry about them printing off any un-approved drawings and trying to get parts made from them.
Ken
Under your line formats toolbar there is a "color mode" selection you could try toggling that giving it a color. It will effect the entire drawing mind you, but you can control the colors on those as well.
Scott Baugh, CSWP [pc2]
"If it's not broke, Don't fix it!"
faq731-376
