B
bikerdude
Guest
Gents (and ladies),
I'm trying to create a VM copy of our server which hosts Windchill 10, PDMLink M020 and after much agro from IT, I finally have a server on our network that I can use and abuse. The downside is that the server name had to be changed (can't have two servers on the network with the same name).
When I try to run Windchill on the VM copy, it defaults to looking for the applications on the real server, which isn't particularly helpful. I need to configure Windchill to look for the Apache/Tomcat/Windchill applications on the VM copy...
I've never done this before. From what I understand I need to modify an .xconf file, and run it in xcomfmanager under a windchill shell.
If what I've said is correct, then the two unknowns for me are:
1: which xconf file do I need to modify
2: What command do I run with xconf manager in the Windchill shell?
Any advice you can give me would be great as this is a new process for me. The whole reason for doing all of this is to have a play area for doing a dummy run when we upgrade from PDMLink M020 to M040.
Thanks,
Leo
Thanks,
Leo
