Creating a Points Coordinates Table - Catia R19 2
You could also do it directly in the CATIA drawing by using the Coordinate Dimension Table.
Just make a view of your CATPart, then select all the points to be included and INSERT + DIMENSIONING + DIMENSIONS + COORDINATE DIMENSION TABLE.
Much easier & quicker then other method.
jackk (Mechanical)
CATIA drawing by using the Coordinate Dimension Table (as you suggested) has always 0 value for Z!
How about if you have points in 3 D with different value than 0 on Z?..................
They aren't showed on drawing!
MZ7DYJ
Go to the view Properties and turn on 3D POINTS. Use these points for your table.
Also, make sure you choose one of the 3D axis systems at the top of the pop-up window.
Great, thanks!
MZ7DYJ
mz7dyj
I've been working on a macro for this exact purpose. We make pipes and similar structures at my job so I put together this macro to speed up things.
It takes points from the 3D, extracts the x, y and z coordinates and makes a table on the drawing. You can use this as a guide and tweek things if needed.
Code:
'This macro extracts 3D coordinates for points and creates a complete table on CAT drawing.
'with X, Y and Z coordinates.
'Instructions for use:
'Drawing as window 2.
'Select points and run macro, input table headline and letter.
'Table with 3D coordinates will be created in the view "TABLES".
'Created by Per Björk, 2014
Dim coords(2) As Variant
Dim letter, tabHeadline as String
Dim numberOfPoints, selWin as Integer
Dim foundTables as Boolean
Sub CATmain()
	'selWin = inputBox ("Which window contains the drawing? Ex. 1, 2, 3...")
	tabHeadline= inputBox("Table headline?")
	letter = inputBox ("Which letter? Ex. A, B, C...")
		dim selection1 as Selection
		Set selection1 = CATIA.ActiveDocument.selection
		numberOfPoints = selection1.Count
		Set myWin = CATIA.Windows.Item(2)		'activate drawing window
 			myWin.Activate
		Dim myDoc As DrawingDocument				'define active document and drawing view
			Set myDoc = CATIA.ActiveDocument
		Dim mySheet As DrawingSheet
			Set mySheet =  myDoc.Sheets.Activesheet
		for i = 1 to mySheet.Views.Count				'check if drawing view "TABLES" exists
			Dim myView as DrawingView
				set myView = mySheet.Views.Item(i)
			Dim MyPrefix, MyIdent, MySuffix As CATBSTR				'initate getViewName
 				MyView.GetViewName MyPrefix, MyIdent, MySuffix
			if MyPrefix = "TABLES" then				'if "TABLES" exists activate view and exit for loop
				Set myView = mySheet.Views.Item("TABLES")
					myView.Activate
						foundTables = TRUE
							Exit for
			end if
		next
		if foundTables = FALSE then				'if "TABLES" doesn't exist, create and activate it
			Set myView = mySheet.Views.Add("TABLES")
					myView.Activate
		end if
		'create the table itself
		Dim MyTable As DrawingTable
 			Set MyTable = MyView.Tables.Add(100, 100,numberOfPoints + 2 , 4, 7.5, 20)
		'add labels
		MyTable.SetCellString 1, 1, tabHeadline
		MyTable.SetCellString 2, 1, "POINT"
		MyTable.SetCellString 2, 2, "X"
		MyTable.SetCellString 2, 3, "Y"
		MyTable.SetCellString 2, 4, "Z"
		MyTable.MergeCells 1, 1, 1, 4
		MyTable.SetCellAlignment 1,1, CatTableTopCenter
	For i = 1 To numberOfPoints 				'create correct number of rows
		Set element = selection1.Item(i)
		Set selPoint = element.Value
		Set TheSPAWorkbench = CATIA.ActiveDocument.GetWorkbench("SPAWorkbench") ' set TheSPAWorkbench
         		Set TheMeasurable = TheSPAWorkbench.GetMeasurable(selPoint)             ' set Measurable with reference
            		TheMeasurable.GetPoint coords              ' get coordinates from Measurable
				'add point name
				MyTable.SetCellString 2 + i, 1, letter & i
					xPoint = round(coords(0),1)	'check decimals
						if int(xPoint) / xPoint = 1 then		'check if integer
							MyTable.SetCellString 2 + i, 2, xPoint & ",0"		'add ",0"
						else
							MyTable.SetCellString 2 + i, 2, round(coords(0), 1)		'else, use 1 decimal
						end if
					yPoint = round(coords(1),1)			'same procedure for y and z
						if int(yPoint) / yPoint = 1 then
							MyTable.SetCellString 2 + i, 3, yPoint & ",0"
						else
							MyTable.SetCellString 2 + i, 3, round(coords(1), 1)
						end if
					zPoint = round(coords(2),1)
						if int(zPoint) / zPoint = 1 then
							MyTable.SetCellString 2 + i, 4, zPoint & ",0"
						else
							MyTable.SetCellString 2 + i, 4, round(coords(2), 1)
						end if
	Next
		MsgBox "Coordinate table created!" & vbNewline & "Points are presented in order of selection."
End Sub
Nice, thanks MecaTron101 !
MZ7DYJ
