Creating a macro to automatically generate a drawing 1
nickjb
GB
I am considering writing a macro for setting up 2D files for our CNC machine. What I want it to do is create a drawing of an assembly and add a 'top' view for every individual part within the assembly. I have a 'manufacture method' custom property so I might use that to weed out the parts that don't use 2D CNC but for now adding a view of every part would be a good start.
Before I begin:
Has someone done this before and is willing to share?
Is it going to be hard to write and more trouble than it is worth?
I've written a few macros but I'm pretty new to it so not sure where to begin. Any helpful hints and tips would be appreciated. Some suggested code would be even better :)
A good place to start might be to record a macro performing the operations you desire. Then edit the code to clean it up and do more stuff.
You can also check these couple sites... Great resources for SW macros:
-Dustin
Professional Engineer
Certified SolidWorks Professional
Certified COSMOSWorks Designer Specialist
Certified SolidWorks Advanced Sheet Metal Specialist
I've not used the task scheduler before. I've just had a quick look at it and can't see how it would help in this instance. Can you elaborate, please?
Use the "create Drawings" option in the task Scheduler.
If you set up a drawing template with predefined views you can tell the task Scheduler to use the template and which folder to pull model files from.
Task Scheduler will keep creating drawings until the model files run out.
You can set up your template with custom properties so they are automatically filled out at drawing creation and if you set the template settings correctly you can also aautomatically import model items and dimensions at drawign creation.
For simple parts it will work great. For more coplex parts i'd just stick with adding the drawing views, custom properies.
Rob Rodriguez CSWP
Eastern Region SWUGN Representative SW 2007 SP 2.0
Thanks, but I want to create a single drawing containing a 'top' view of each component in the assembly.
nickjb ... Are you trying to create a nested layout for the CNC machine? Are these sheet metal parts?
CBL, That's the idea. I've got an assembly of say 5 parts. I want to generate a drawing (for exporting as a DXF) with 5 views. 1 top view of each part in a single drawing.
They don't need to auto nest as its easy to shuffle them around. Its the opening of each part to create the view that is time consuming. They are wood or plastic parts to be cut from sheet.
rockguy, I can't seem to find the feature in task scheduler that will allow me to do this. Can you point me in the right direction.
nickjb,
What version os SW do you have? If it is core SW you will not find Task Schedular. It is in the higher versions of SW.
Cheers,
Anna Wood
Anna Built Workstation, Core i7 EE965, FirePro V8700, 12 gigs of RAM, OCZ Vertex 120 Gig SSD
SW2009 SP3.0, Windows 7 RC1
Its SW 2007 Education version. Its got all the tools expcept the PDM. I've got the Task Schedular but I can't see how it could do this.
I've made a start with a Macro
I've managed to generate a list of parts in the assembly (with help from google and published code). Struggling a bit to create the drawing. I tried recording a macro but that flashed up loads of errors
' C:\DOCUME~1\NICKBA~1\LOCALS~1\Temp\swx240\Macro1.swb - macro recorded on 08/06/08 by Nick Banks
Dim swApp As Object
Dim Part As Object
Dim SelMgr As Object
Dim swView As String
Dim swFileName As String
Dim swFilePath As String
Dim swParts(0 To 100) As String
Dim boolstatus As Boolean
Dim Feature As Object
Dim Child As Object
Dim ModDoc As Object
Dim i As Integer
Dim j As Integer
Dim Children As Variant
Dim InfoText As String
Dim swModel As Object
Sub main()
Set swApp = Application.SldWorks
Set ModelDoc2 = swApp.ActiveDoc
Set Configuration = ModelDoc2.GetActiveConfiguration
Set Component2 = Configuration.GetRootComponent
Set ModDoc = Component2.GetModelDoc
Children = Component2.GetChildren()
ChildCount = UBound(Children) + 1
i = 0
Do While i <> ChildCount
Set Component2 = Children(i)
swFileName = Component2.Name2
swFilePath = Component2.GetPathName
InfoText = InfoText & "Item " & i & swFilePath & " End" & vbNewLine
swParts(i) = swFilePath
i = i + 1
Loop
MsgBox InfoText, vbOKOnly
Set Part = swApp.NewDocument("*.drt", 12, 0.2794, 0.4318)
Dim DrawView As Object
i = 0
swView = swParts(i)
MsgBox ("creating view: " & swView)
'Create view
i = i + 1
Loop
End Sub
Dim swApp As Object
Dim Part As Object
Dim Child As Object
Dim i As Integer
Dim j As Integer
Sub main()
i = 0
i = i + 1
Loop
i = 0
swView = swParts(i)
'Create view
'How????????
i = i + 1
Loop
End Sub
Howdy,
Attached is a macro that might have some code you'd be interested in. This macro won't actually work for you unless you change it to point to your Template names and locations.
Hope this helps
Tobin Sparks
www.nov.com
 http://files.engineering.com/getfile.aspx?folder=be06bf8a-c313-4899-90a2-1db8aa1153e1&file=AutoStartDrw.zip
Thanks Tobin. That got me heading in the right direction. The first draft is working now. Needs tidying up and finessing.
Dim swApp As Object
Dim Part As Object
Dim swType As String
Dim Child As Object
Dim i As Integer
Dim j As Integer
Dim TopAssy As String
Dim longstatus As Long, longwarnings As Long
Dim PosX As Double, PosY As Double
Sub main()
Set swModel = swApp.ActiveDoc
TopAssy = swModel.GetPathName
swType = swModel.GetType
If swType = swDocASSEMBLY Then
InfoText = ""
i = 0
InfoText = InfoText & "Item " & i & swFilePath & " <" & vbNewLine
i = i + 1
Loop
i = 0
swFilePath = swParts(i)
' MsgBox ("opening: " & swFilePath)
Set Part = swApp.OpenDoc6(swFilePath, 1, 0, "", longstatus, longwarnings)
swApp.ActiveDoc.ActiveView.FrameLeft = 0
swApp.ActiveDoc.ActiveView.FrameTop = 0
swApp.ActiveDoc.ActiveView.FrameState = 1
Set Part = swApp.ActivateDoc2(swFilePath, False, longstatus)
If Part Is Nothing Then
Call MsgBox("Unable to open document!", vbExclamation, "Line3") ' Display error message
End If
i = i + 1
Loop
Set Part = swApp.ActivateDoc2(TopAssy, False, longstatus)
sTemplateName = "\\srv-Lancelot\aardvark\CAD\Templates\Pacer CNC.slddrt"
Set swDrawing = swApp.NewDocument(sTemplateName, swDwgPaperAsize, 0#, 0#)
' display sheet format
Set swNewSheet = swDrawing.GetCurrentSheet
swNewSheet.SheetFormatVisible = True
swDrawing.EditSheet
i = 0
swView = swParts(i)
'MsgBox ("creating view: " & swView)
PosX = 0.3 + (0.2 * i)
PosY = 0.3 + (0.02 * i)
'Create view
DrawView = swDrawing.CreateDrawViewFromModelView(swView, "*Top", PosX, PosY, 0)
'set scale
boolstatus = swNewSheet.SetScale(1, 1, True, True)
i = i + 1
Loop
End If
If swType = swDocPART Then
MsgBox ("Its a part")
End If
End Sub
Hi Tobin , thanks for the macro. Can you edit the macro to work for part configuration. I'm try to create a macro that will create flat pattern export as dxf of each configuration in the sheet metal part.
Deepak Gupta
SW2009 SP3.0
SW2007 SP5.0
MathCAD 14.0
Howdy,
I'm glad you like the macro. Unfortunately I'm not in a position to do much for others outside the company I work for. I'd be glad to share anything I may have done though.
I could be wrong, but, I'm pretty sure SolidWorks will only generate a *.dxf file from an existing *.slddrw document. I don't know of a way to go straight from *.sldprt to *.dxf, there would have to be a *.slddrw in between. If that's what your asking :-)
Tobin Sparks
Thanks Tobin for the courtesy and I can understand the situation.
Thanks CBL for the info and I have been trying it.
I have been able to make the macro (by combining 2 macros) but getting issues with the file name. Being a beginer I'm not able to fix the file naming issue. The file name should be file name followed by config name.dxf but it comes as file name should be file name.config name dxf
Here are the codes if someone can fix
Code:
Option Explicit
Sub main()
    Dim swApp                   As SldWorks.SldWorks
    Dim swModel                 As SldWorks.ModelDoc2
    Dim vConfNameArr            As Variant
    Dim sConfigName             As String
    Dim nStart                  As Single
    Dim i                       As Long
    Dim bShowConfig             As Boolean
    Dim bRebuild                As Boolean
    Dim bRet                    As Boolean
    Set swApp = CreateObject("SldWorks.Application")
    vConfNameArr = swModel.GetConfigurationNames
    For i = 0 To UBound(vConfNameArr)
        sConfigName = vConfNameArr(i)
bShowConfig = swModel.ShowConfiguration2(sConfigName)
bRebuild = swModel.ForceRebuild3(False)
Dim FilePath As String
Dim PathSize As Long
Dim PathNoExtension As String
Dim NewFilePath As String
FilePath = swModel.GetPathName
PathSize = Strings.Len(FilePath)
PathNoExtension = Strings.Left(FilePath, PathSize - 6)
' This line generate the file name with extension but it is not coming  as expected
NewFilePath = PathNoExtension + sConfigName & "DXF"
'Export Flat Pattern
 bRet = swModel.ExportFlatPatternView(NewFilePath, 1)
 Next i
End Sub
Deepak Gupta
SW2009 SP3.0
SW2007 SP5.0
MathCAD 14.0
Howdy,
Well - I'm so glad I started that sentence with "I could be wrong, but," :-). Thanks for bring me up to date on that CBL.
Deepak your code worked great for me when I added the "." before the "DXF", like ".DXF".
Tobin Sparks
