Greetings wiseones,
I am in need of suggestions on a method to put a cutout that is of uniform depth along a radial surface. Basically, I have a thin walled semi-sphere shape that is 2 mm thick, and I need to put grooves that are 1 mm deep on the out side. The groove need to run from the top down to the end of the semi-sphere.
Suggestions, please..
Thanks,
Thanks,
