Creating a crown.
1fstgm
7
What is the best way to go about creating a crown like part. Very similar to that of Burger King's Crown. I know some pattern would help, but detail would be nice. Thanks!
Create a revolve for the basic shape.
Cut out a curved notch and then circular pattern around the revolve.
Add a sphere to one of the peaks and also circular pattern around revolve.
[cheers]
I would create a ring. Then make the spike of the crown as a lofted part and pattern the loft.
Heckler
Sr. Mechanical Engineer
SWx 2007 SP 3.0 & Pro/E 2001
XP Pro SP2.0 P4 3.6 GHz, 1GB RAM
NVIDIA Quadro FX 1400
o
_`\(,_
(_)/ (_)
(In reference to David Beckham) "He can't kick with his left foot, he can't tackle, he can't head the ball and he doesn't score many goals. Apart from that, he's all right." -- George Best
You'll have to define the details. How many points on your crown do you want? The number of points will define the spacing of your pattern. Perhaps if you elaborate on your application, you will get more relevant answers. What materials are you considering for your crown? Knowing this can give us hints as to the manufacturing process, which can lead to different modeling techniques, which will yield a model that is more appropriately designed/built.
Matherjd, it would be helpful in the future when you are making model files available for download to indicate the SW version the models are created in. Not everyone is on the same version or service pack.
"Art without engineering is dreaming; Engineering without art is calculating."
Have you read faq731-376 to make the best use of Eng-Tips Forums?
