Hi,I'm trying to create a model of a O-ring that can be easily added to an assembly. Basically, what I'm hoping for is to insert the o-ring into an assembly with some kind of dialog pop up prompting the user for the inside and outside diameters and the part number. When these properties are entered, a configuration will be generated based on those dimensions and saved to the part. Similar to the process of adding bolts to an assembly except there are non standard sizes. Any suggestions to get this functionality would be greatly appreciated. Thanks.
PS I'm using SW 2005
